De Dion
Minicooper - 31/8/05 at 07:52 PM
Thanks in advance
With IRS you set the camber and toe, what do you do with the dedion is it perfectly square in both planes?
britishtrident - 31/8/05 at 08:10 PM
A tiny bit of toe-in and a small dash of negative camber say -0.25 degrees.
Mr G - 31/8/05 at 08:18 PM
Originally posted by Minicooper
Thanks in advance
You can adjust both later on with shims if you don't want to produce 'built in' figures to the de-dion axle.
G
