can some one tell me the pcd of a ford sierra diff flange
thanks
[Edited on 21/9/05 by iceman26]
You also need the angle from centre aswell as the PCD iceman... the holes on our input shaft are not equispaced. The holes will only line up in two
out of the four positions available.
Your better of getting a template made up if you are making a mating part.
probably no help but they are the same as the atlas (capri) axle.
