Hey guys whats wrong over here??
wy does it disengage..?
Hope some one can tell me..
Tks
I cannot see a great deal from the picture, but the plastic part of the bearing which is on the column seems to be the wrong way around.
What exactly is disengaging?
..a picture of mine
Looks like the circlip that should be above the inner bush to stop it rising up is missing
As you can see in Marks picture the circlip is about 80/90 mm above inner bush. When bush is in place circlip should just touch top of bush.
Yep, it's all fitted right, but the triangular funny clip thing is missing.
Push the inner bush back down trough the other one and use a tie clip around the shaft to stop it sliding up again.
Pat...
I've got one of them spare in the kitchen atm, just had a look to see if it's still there and it is.
If you U2U me your address, I can send you it on Monday.
That's if I don't break it taking it off
Put a jubilee clip or a tiewrap round it to stop it riding up. It's because it,s taking up some misalignment.
The washer/clip that is missing is 36p from Ford.
