i am using a capri axle so the diff is not in the middle, does it matter if the propeller shaft is not straight inline with the gearbox or can the shaft run at an angle
The prop is suposed to be from right to left from the front m8... Not straight anyways..
thanx
A pdf on the way to you both about salisbury axles in the chassis, the prop must not run straight or the UV's will wear out prematurley
