I HAVE TUREND MY STUB ADAPTORS UP AT WORK BUT CAN ANYONE TELL ME WHAT THE TAPER IS ON A TRANSIT BALL JOINT
I'm sure this has been asked before,Although i thought it was only the bottom ball joint needed a taper.
I know the bottom B/J taper goes from 12mm to 14mm if that helps
If its any help the track rod end taper on a sierra is, I'm told, 7degrees. I suppose it's likley/possible to be the same for the Tranny
[Edited on 25/2/03 by jonti]
7.5 from memory
I'm sure 7 will do!
Chris
I just checked a pilgrim build manual and they sat 7 degrees for bottom taper as well
