I know everybody has his own preferences, but I would like to know which diameter steeringwheel would be best for a car engined Seven. Is 260 mm too
small? Is 300 too big? Is 280 perfect?
Any suggestions?????
[Edited on 27/2/03 by Mave]
Heuh? Nobody's got an opinion? Some help please
Point is: is saw a nice RaceTech steeringwheel (260 mm) but I would like to know if it's too small for comfort.....
260mm seems to be the most popular
Depends upon so many things
How wide are your front tyres ?
What rack are you using ? (quick rack needs more grunt to turn than standard)
How strong are you ?
Are you going to be just racing ie all high speed stuff ? or doing a lot of low speed parking at Tescos ?
For what its worth mine is 280mm D . With a standard Sierra rack and 195 section tyres it works fine and looks good ( well I think so anyway but then
I like 'em a bit bigger !.. oo er missus ! ))
[Edited on 27/2/03 by jonti]
Something small - so as you can drive in handcuffs. Mines 340 mm tho................... as is my steering wheel
Chris
Originally posted by chrisg
Something small - so as you can drive in handcuffs. Mines 340 mm tho................... as is my steering wheel![]()
Chris
I once drove a 105E Anglia from Basingstoke to a little place called Wivelrod, near Alton, with a pair of 10" Molegrips clamped to the steering
column, as some kind folk had removed my nice new Mountney wheel while I was having a pint.
So that's the equivalent of a 250mm wheel.
