I'm missing some spacers (probably 2) from the clamping mechanism off my Sierra adjustable column. Can anyone describe them or post a picture of
what they look like?
I'm sure they must be around somewhere if only I knew what they looked like!!
Sierra adj. column
Gary
[Edited on 1/2/06 by GaryM]
Hi there
They are odd shaped black plastic things. Kind of look like squares with the corners nibbled off. No picture I'm affraid.
Liam
I'll have a look at my column when I get home and send you a picture.
No smutty combacks please
i modded my adjustable column. Packed it out with washer, cut the handle off and nipped the adjuster up tight.
I can still adjust if reqd but its no longer a quick one handed job (no joke intended
