Following on from the earlier discussion, can anyone recomend a compact servo & M/C?
I'd like it to have M10 fittings if possible.
Chris
Er....thanks.
cheers
Chris
Chris, my Locost has servo assisted brakes. The servo came form a Nissan Micra.
It does make things cosy at the end of the drivers footwell and I had some difficulty fitting the clutch m/cyl. It does fit though and it works very
well. Light pedal but lot's of 'feel'.
Thanks justin, do you happen to know if it has the M10 fittings? and which Model of micra it's from?
Chris
Hi Chris,
yep it's M10 ports all round. Which model is a good question and I don't know the answer. I got it via another route - all I know is it has
the 20.64mm diameter, steel tube type m/cyl'.
You can see it in this picture;
The LH engine mounting, made by my own fair hand!
[Edited on 13/2/06 by JAG]
Thanks mate, looks like the early square shaped Micra.
Chris
