I've just heaved out the knackered old oil seal from the back end of my Type 9 gearbox. I have noticed that the splined shaft has a bit of
side-to-side movement - is this normal?
Or do I have to take it to bits to repair a bearing...
Yup the mainshaft bearing is a long way up the tube so about3mm each way is reasonable
