Pedal box advice please?
mattandmike - 17/2/06 at 09:56 PM
Hi all!
Anyone got any diagrams/photos of a pedal box using Escort pedals? (Top mounted).
I'm a skinflint, & can't afford a floor mounted set up, so really need to use the donor items if I can. Trouble is, I'm not sure the pedals & steering column will fit in together?
I have no problem in cutting & shutting the pedals, but would appreciate seeing how other builders have coped?
DavidM - 17/2/06 at 11:41 PM
I used escort pedals in a home made pedal box. There are some pictures in my archive. The box is made out of 2mm plate and the steering column is routed between the pedals.
Hope this helps.
Danozeman - 18/2/06 at 09:39 AM
I made my escort pedals into a floor mounted set up. I just chopped the pedals and made up some brackets. Will try and get some piccies.
See here dude for my thread on converting it may be of use.
[Edited on 18/2/06 by Danozeman]
mattandmike - 18/2/06 at 12:10 PM
Thanks to both for the replies.
David.
Thanks for this. Have you got any pics from the top down so that I can see the relationship between pedals & column?
Danozeman.
Pics would be good as this sounds a neat solution.
