has any 1 got pictures of shortened hand brake cables for sierra rear discs and how do you do it
thanks
i used trailer brake cables on my avon, works very well. http://www.trailertek.com/acatalog/Non-detachable.html
You need one of these ....... only one that is in focus
Just cut the inner cable to the required length - enough to take up the slack (I think I
cut 200mm off mine) and reattach the new cable end.
Then adjust as normal.
These can be bought from MK for £3.00 IIRC
[Edited on 25-2-06 by RazMan]
