How Big is Yours.....?
Jon Ison - 17/4/02 at 07:25 PM
don't get too excited......what size steering wheels you useing, and would you have gone bigger/smaller given the chance....
thanks in anticipation...Jon.
David Jenkins - 18/4/02 at 07:24 AM
I'm using the original Sierra wheel until after the SVA, then I've got a nice 12" leather-bound one that's going straight on...
Dunc - 18/4/02 at 08:00 AM
380mm, but hey, diameter isn't everything is it.
Yes it's the original sierra one till after the SVA. Or maybe till after stoneleigh, last year there was a pile of mountneys for only 2 or 3 quid each, they were a bit tattie but you can't knock that price, didn't have the adpaters though.
JohnFol - 18/4/02 at 09:26 AM
On roughly the same subject, is a collapsable steering column part of the SVA? I have a column from a Mk II Escort but the book wibbles on about collapsable from Allegro / Nova's
StuartA - 18/4/02 at 11:33 AM
John,
SVA states that:
"A vehicle may be assessed on its merits but will invariably require the steering column shaft to incorporate an arrangement of universal joints/ couplings and/or a collapsible tube/slider section that ensures displacement of the upper column is minimized"
There are other bits in there about collapsible columns too. We've taken ours from a Sierra, which I believe is pretty standard.
David Jenkins - 18/4/02 at 12:06 PM
Just to cover as many options as possible, I have:
1. A non-braced bit of chassis in front of the steering rack (it protects the bottom of my radiator)
2. A pair of universal joints that displace the steering column by a few degrees
3. A joint that would collapse on impact (where the Sierra steering down-link joins the steering column)
4. A collapsible tube in the steering column
...I think I've covered all the angles!
Anyone who uses a Sierra column should have items 3 & 4, even if the angle in 2 is insufficient (as mine probably is)
My motto is to minimise the possibility of complaints in the SVA!
theconrodkid - 18/4/02 at 11:11 PM
I had to get a colapsible boss for my wheel,watch those cheap wheels,there may be a reason for them being so cheap like not sva compliant
