bit of a scrub and some paint and doesnt she come up nicely
sml diff
diff sml1
[Edited on 5/3/06 by locoboy]
7.5" Cossie LSD?
Looks rather nice
smart paint job there. . .looks like it was made to fly.he he
Nice Job!
Ok I have to know, becuase my diff is out and I've always wanted to get it loking new. What paint did you use?
I bought some silver "Aluminium Paint" but it turned out it contained aluminium and could be painted on wood or ferous metal... DOH!
That looks GOOD!
Charlie
If you ever reverse over anybody they will be in for a real treat
You can use wheel silver aerosol paint on your aluminium stuff to tart it up Charlie.
If I was a prop shaft i would'nt mind been stuck up that......
Looks brand new!!
i pimp'd my diff to
You guys have *way* too much spare time. I am deeply jealous!
Richard
ive been on holiday from work for two weeks so ive had a few days here and there
7.5" Cossie LSD?
Looks rather nice![]()
I pimped mine, well I lagged it with red smoothrite!!
Nice work bench Mark! If I did that SWMBO would castrate me.
arnt you married mate or was the other half out for the day
Originally posted by the_fbi
7.5" Cossie LSD?
Don't think its a 7.5", the top mounting doesn't appear to be any longer than a 7" one.
It does however look very very nice. I think "bit of a scrub" is a large understatement!
A 7.5" Diff has mounts like these..
HTH
PS This one is a Cossy LSD
Soon to be painted after seeing everyone elses...
[Edited on 5/3/06 by chasmon]
7.5" Cossie LSD?
Reason I ask is that I am reliably informed 7.5" diffs have a solid top mount (as on Locoboys) and 7" ones have a cut away top mount. I asked a question about it a while back!
guys,
Its a 7.5 Cossie LSD, Flak you know your diffs!
Seriously all i did was use Gunk foam aerosol degreaser,
steam wash it at work
then yesterday morning give it a good session with the hand held wire brush and then using a jewelers screwdriver to scrape the oxidisation off in the
deep holes between the strengthening ribs.
2 coats of Wliko's own metal primer (spray)
then 2 coats of Plastikote metalic silver spray (up to 240deg C)
The back plate was done with the same primer and then using Plastikote Black super gloss as top coat.
The bolts and plug were done in the metalic silver.
All in all probably about 3 hours work. I had to replace the backplate anyway as it was cracked so thought i should make the effort whilst it was off
I used gunk on mine to get most of the grease off, then chucked it in the bead blaster.
Simon
Simon
That's straight GANGSTA, dawgs!!
I pimped ma gearbox... Tha bolts are twenny-fo carrat gold, dawgs. Twenny-fo carrat GOLD!!!
gawd blindme
feeling all inferior now wiv all theze blinged bitz!!!
My stuff just got caustic, wash and quick whiz over with some glass bead!
NEED MORE TIME!
