can't find my haynes, think its about 25 miles away. for some reason i have 27-28lb/ft in my head, can someone set me straight please?
search didn't bring it up unless i missed it.
ta muchly,
Ned.
The front ones just tighten up till theres no bearing play. I tighten mine till the wheel binds then slacken them back off till it frees up. I
don't think there's an actual torque setting for them.
[Edited on 6/3/06 by Peteff]
As Pete says. The fronts do up till the hubs stiff then back off a flat of the nut.
Theres a download on my site (in downloads section, called something like "upright recon"
. The torqu IIRC is 28ftlb then back off 90
degrees.
[Edited on 6/3/06 by flak monkey]
i did it hand tight with just a socket over the nut, then backed it off to the last pin notch. Thats probably not too far off 28lbft anyway!
yep, no torque value for these, just give em a good nip if new bearings have been fitted to make sure they are seated well, then back off to a suitable split pin hole and check there is no play.
My 1st car was an old escort 1100(mmmmm) The haynes manual had that nonsense about tighten to a totque & back off 90. They were never adjusted
right. Now with the taper rollers I always tighten with a pair of pliers till they feel right.
BTW it IS worth doing the 28ftlbs thing once when you rebuild to ensure the bearings are seated correctly.
cheers
Bob
