Handbrake Brackets
The Doc - 5/6/06 at 06:17 AM
Hi Folks
Anyone got pics of their arrangement for mounting the handbrake cables on the rear axle?
All seems a bit tight to me, getting passed the panhard rod and getting the angle down to the lever
Also where can I get those 'abutment' pieces from (the plastic stops that go in the other hole in the lever) or - do we really need them for SVA?
britishtrident - 5/6/06 at 07:03 AM
Which axle & rear brakes ?
With Escort or Capri axles the back plates can be rotated and re-drilled.
RoadkillUK - 5/6/06 at 02:44 PM
Hope this helps, Escort axle with allegro cables.
Michael - 6/6/06 at 08:20 PM
Mines the same as roadkill, just thinking when mine are refitted if i need to make the cables more secure.
By the way Roadkill what engine have you got that pump for?
RoadkillUK - 7/6/06 at 10:36 AM
It's for the trusty 1.6 X-Flow
