Ford LSD overhaul.
Chippy - 12/6/06 at 10:45 PM
Hi, can anyone tell me if its feasable to carry out an overhaul on the above. I have quite a bit of backlash in the CW and pinion, can this be shimmed out? Also the LSD part is pretty weak, quite easy to turn, I understand this should be somewhere in the 70lb pressure range. Are any overhaul kits available. Any help gratefuly recieved. Thanks Chippy
tks - 13/6/06 at 08:49 AM
there is some pdf on the net.
the link should be on this forum.
so if you search you should find.
the procedure was as original ford.
Tks
