Taking apart the Master cylinder
dirty130 - 13/6/06 at 07:12 PM
Has any one taken apart the vacum on the master brake cylinder? i need the push rod out of the center im just about the brake the vacum apart any ideas?
theconrodkid - 13/6/06 at 07:35 PM
there is a huge spring in there designed to take your face off if you split the servo,saw the pushrod off where it pokes out and extend it
James - 14/6/06 at 08:02 AM
Cut mine open with a grinder. Kept cutting till I had the bits I wanted.
Wear goggles, gauntlets and ear defenders!!!!!
HTH,
James
