Fiat 125 Rear Axle
guzmanp - 14/6/06 at 11:42 AM
I'm planning the construction of my Locost with a Fiat 125 donor car. I'm double checking the dimension and the rear axle of the fiat is 50.7" between brake drums, is this meassure enough for the book chasis? and for the 442 ??
locost_bryan - 15/6/06 at 03:04 AM
Should be ok for a book chassis - Estfield use the Lada clone.
Someone here is building with a 125, so you should be ok.
procomp - 15/6/06 at 06:50 AM
Hi i think as said it's the same as the lada one . Whitch we use on book chassis. For a wider version there is the lada 4x4 niva whitch is 100mm wider.
cheers matt
