Anyone know what is going on here?
Whats that on mark? Its a tidy idea
Its a guess but it looks a bit Japanese.
Steve.
Are you sure it alters castor?
The ball joint pin is still bolted into the casting. Adjusting the bolt would only alter the ball joint position in relation to the upright. The
wishbone centers would still be the same.
It is hard to see if the plate moves within the upright though, from the photo, so I could be wrong.
[Edited on 18/6/2006 by nitram38]
Its a a VW Transporter T4 set up and it is to adjust the camber.
To adjust castor you need to physicaly move the upper balljoint back or forwards in relation to the lower one. If that scheme was adapted to move the upright back and forwards with relation to the balljoint then it would be essentialy the same as the Sierra upright offset mushroom adpaters.
