I need to replace my donor master cylinder - Girling steel tube type from a 2.0 SOHC sapphire.
Best price I have found is ~£78 from Brakes Int, but that seems a bit steep. Anyone suggext a cheaper source?
They also sell overhaul kits for ~£25 - what sort of job is it to strip and rebuild?
Nick
Rebuild depends on the state of the bore, ie whether its scored or not. no good putting in a repair kit if the bore is scored.
What about a scrap yard job?.. get a couple while you are there
Brakepats are very good... sound like an expensive bit.
Also tried Ebay?.
I've got 3 sierra master cylinders that came with my part built kit if any of them are any use mate?
I'm using a lightweight alloy jobby ford unit instead.
If you're interested I can take some pics and they are yours for the price of postage
Ben
Hi nick, had to replace mine also.
Got mine from
Totton Motor Factors
water lane
Totton
SO40 3DN
£50
02380863631
Are you nearly finished?
Cheers Nige
Hi Pezza - U2U sent cheers!
Hi Nige!
Not there yet I'm afraid, but building up steam
I'll give Totton factors a call and see if they can help.
Part of the problem is that I have already installed the old one and so I want to replace with the same to avoid having to move the brake pipes
around. Otherwise I would just pick something suitable and cheap to fit in there
How's yours coming along - any up to date pics?
Nick
I beleive one of the cast ones matches the positions of the connections on the steel tube type - but you also have to be careful about the mounting
hole alignment!
HTH
Hi Nick, My unit that i replaced was the same for mounting fitment and brake pipe position. They had the two types Girling and the other??
Yes nearly finished, a couple of small jobs to do. One is to cut the bonnet for exhaust and carbs, not looking forward to that.
I will post pics soon.
Cheers Nige
