trailing arm brackets
theconrodkid - 25/6/06 at 01:31 PM
ive got a new chassis now,the brackets for the trqiling arms has trailing arm bolt holes about 1" closer together than the brackets i intend on welding to the axle,is this going to cause a prob?
andyharding - 25/6/06 at 01:55 PM
yes
Peteff - 25/6/06 at 04:27 PM
It will give you a rigid mounted axle and crush any bushes you fit, you won't need shock absorbers though .
theconrodkid - 25/6/06 at 06:44 PM
i thought i,d get that answer,oh well out with the pillar drill
