Does anyone know if Sierra uprights fit Maxi ball joints without modification? The uprights I have are already milled out for Cortina ones. Are they
any good now I have Maxi based wishbones?
Chris
seeing as maxi ball joints are used without madification to the hubs from cortinas, if your sierra hubs have been cuf for a cortina, they will fit. Standard sierra hubs will not fit directly though
the mounts for the sierra is a different taper, so a definate no if they fit a cortina.
i calculated it , and its about 2.5 degree and 4 degrees for one or tother.
draw it out on paper at enlarged scale and you will find that there is only a tiny contact point in the taper if you use the wrong joint.
I dont know what people are doing as a solution......
a. get a taper made by an eng firm
b. drill it out and have no taper - might spin a bit when you tighten or undo tho!
c. some other way!
i couldnt see a hand reamer taper that I could use, so I went for my own solution. Its so weird I dont think its worth telling you!
atb
steve
Now I'm confused! I've already had the hubs machined to fit the cortina ball joints but now I want to use Maxi ones. Are the machined ones
any good or do I need to start again on some un-machined ones?
Need to know as I intend on selling the un-machined ones (as they havn't been shot blasted
Chris
I think the taper you should have is 12mm to 14mm or whatever that is in degrees.
I'm sure we have gone through this one before,must be in the archives somewhere or even easier ask at the show.
