Seasons Greetings
Is there a steering column which is slightly shorter i.e. will protrude less through the scuttle when using a Escort quick rack.
The standard Sierra tends to intrude too far into the cabin which, IMO looks poor.
SHORTER STEERING COLUMN
I think escort/orion column is shorter,multi plugs should be the same as sierra pre E-reg
go for the mkiv Escort, shoter and better looing switchgear (if you are using a smaller diameter steering wheel
Dave
