Hi All
I've had a bit of a problem in refitting my rear calipers onto the alloy uprights, as the thread has stripped in one of the caliper mounting
holes. I could drill, tap or try a helical insert but there's an easier option. The uprights are symmetrical so they have caliper mounts at the
front and rear and the mounting holes are OK on the rear mounts.
Can anybody see a problem in mounting the calipers at the rear of the upright instead of the front ? I'll swap the rear calipers over to ensure
the bleed nipple stays on top.
Alternatively, I could swap the rear uprights around but that's a bigger job!
Regards
Wyn
Personally, I'd helicoil it
I'd suggest helicoil, but so long as it is common left to right you should be ok.
I would helicoil it aswell.
Only problem I could see is if you have a handbrake built into the calipers as the cables will need a little bit of re-routing.
Personaly I would helicoil it, in fact I would be tempted to helicoil all of them if the caliper bolts are threaded straight into the alloy.
I moved my front calipers to the front of the discs instead of the rear of the disc like the donor, with no ill effects and the car passed sva this way.
This may be one of the most stupid things I've ever posted, but just in case its not....
If the caliper is on the leading edge of the hub, and you brake, does the rotating mass of the wheel push the tyre into the road?
If so, and the way my brain is currently thinking it through, it does, then the last place you'd want the caliper is on the trailing edge of the
hub, as when you brake the tyre is lifting off the surface and has a higher chance of locking.
It sounds strange seeing as the whole wheel assembly is being braked, but something is nagging me saying the above is true.....
So I'd keep it on the leading edge and helicoil or drill out and stick a bolt straight through (perhaps not possible).
Thanks Guys
It looks like Helicoil is the answer! I've never done this before - it looks easy but I don't want to bu**er up my upright as I don't
have a spare and time is tight!
I've drilled the hole and tapped it for a 10mm X 1.5mm bolt but I'm not happy now I've had this problem. So, should I be buying a 10mm
thread repair kit like
this
The original thread was 3/8" UNC and I'd like to do the other three calipers as well!
Regards
Wyn
Easy to do, only recomendation is to make sure you drill and tap it square and not on the piss. Its easy done, guess how I know this
I like them so much I do this to most alloy bits.
It is common for people to helicoil threaded pieces of aluminium even if it is not damaged, especially if it is to be stripped & rebuilt often as
the helicoil is stronger than the ali. Best bet Helicoil.
HTH
Ian
Thanks guys
Just ordered a 10mm kit from Frost Auto.
Regards
Wyn
Success!
Helicoiled!
Great piece of kit - I should have bought one years ago!
Wyn
Thanks Mike
I would have liked to stay with the same size thread but there was no chance. The 10mm metric helicoil was the next size up - I'll do all the
other uprights over the winter as well.
Regards
Wyn
