Bottom ball joint probs?
andrews_45 - 26/8/06 at 04:38 PM
Hi,
I have two sets of wishbones one from Luego and one from MK both have the same hole patterns. The cortina lower ball joints (as per rons book) will not fit in the locating holes, neither are the bolt holes lined up...
I am guessing that I will be wanting some maxi ball joints?
Ta in advance
nib1980 - 26/8/06 at 05:04 PM
Yep, you'll be spot on, austin maxi is what you want
