Sierra Ignition Key
wicket - 27/8/06 at 05:59 PM
We have the standard Sierra 'stick' type ignition key and just had a spare key cut. The guy in the shop said that because the key he copied from was a bit worn the new one may stick a bit for a few times, he was dead right, the key fits OK and works but there's no way it will come out. Anybody got a trick of the trade to remove it?
JoelP - 27/8/06 at 06:06 PM
worked once for me this, pull til the plastic handle comes off, then grip the stump with a wrench etc, and whack the wrench with a big hammer to pull it out.
Hellfire - 27/8/06 at 07:25 PM
Try some WD40 in the barrel and wiggle it about a bit whilst trying to remove it. If and when you free it, remove all the sharp edges on the new key with some wet n dry. Be sure to grease the key well before trying it in the ignition again (If it ever comes out).
Phil
[Edited on 27-8-06 by Hellfire]
Chazzy - 27/8/06 at 09:48 PM
Buy a new ignition barrel from your local ford dealer, comes with 2 brand new keys
its not locost, but makes using the key nicer, its not worn from 70000m of someone elses sweat and grime.
Chas
PS about 20 quid IIRC
Mark Allanson - 27/8/06 at 10:10 PM
Chas
Actually only a coupe of quid under £50 including the vat, I priced one up as I only have one key for my car
zetec7 - 28/8/06 at 03:35 AM
Try rapidly twisting it back and forth as you pull to get the pins to release. When you get it out, use a Scotchbrite pad or steel wool to "soften" the edges of the teeth on the key. That should make it work fine. As for lock lubricant, try using a "dry" (non-oily) lubricant, like spray graphite. Oils and greaes attract dirt & grit, which can cause the lock to seize up. The graphite spray, though, gets EVERYWHERE (and NEVER comes off clothing or upholstery), so be sure to mask around the lock with a plastic bag or something when spraying it into the lock.
zetec7 - 28/8/06 at 03:37 AM
...and I should have mentioned that the graphite spray is black as soot. It even stains skin for several days! But, if sprayed onto metal, it stays almost forever when dry.
rusty nuts - 28/8/06 at 06:26 AM
Got a new barrel and 2 keys from a Ford parts dealer off of ebay for £20 inc P&P . 5 minute job to fit and you don,t need to remove the stuck key.
BKLOCO - 28/8/06 at 06:45 AM
If you get the key cut properly, on a proper machine, from the code rather than coppied, It should be ok.
When I got mine cut he looked at the key, worked out the code, entered it in the machine and cut me a new key.
Works perfectly.
Peteff - 28/8/06 at 09:08 AM
Here it shows you how to read the key and the link to the ignition shows how to rebuild the barrel. I bought a car years ago with the locks superglued and found this stuff out for myself but this is useful. My Sierra only had one key and I read it and got one cut on the market for a couple of quid instead of the price the Ford dealer wanted.
[Edited on 28/8/06 by Peteff]
