Apologies if the subject was a bit misleading, but may be relevant
What are those things called which go on the end of throttle cables where they go into the pedal, with a little grub screw to hold the cable in
place?
I need one, but don't know what I'm searching for.
ta
Chris
Try vehicle wiring products.
What these
Regards
Rich
Try your local motorbike shops for solderless nipples.
I dont suppose anyone has seen these but integral with a clevis?
edit:
ah found this might be usefull.
[Edited on 27/8/06 by Gav]
Hm... None of the kart ones are suitable
I need one with cable entry and grub screw both on the circumference. + the diameter needs to fit in the hole in the pedal.
I'll try and drill through a bolt and then clamp the cable between a couple of nuts. Or just phone Westfield for the proper item
This'll do with a bit of luck.
http://cgi1.ebay.co.uk/ws/eBayISAPI.dll?MakeTrack&item=180013043492
http://www.zoomkarts.com/product.asp?productID=121. I think that the above may be what you are looking for. ATB Ray
Iv got a thing the same as that one on ebay for my choke. It cam from a peugeot throttle cable kit...
