Has anyone got an exploded diagram for the wheel hub, bearing and upright. On the Mk3 'tina uprights spigot i have a The hub, bearing and
retaining nut. Anything else go on there?
Would prefer an answer before 5 to get any other bits ordered if needed.
There's a cover that goes over the nut to enable you to use a split pin to lock the bearing nut to the shaft, and I think there is a large washer
that fits before you put the nut on.
Check your stud lengths, you may need longer ones depending on your alloys.
Disks, Calipers?
