Wishbone Sizes?
mistergrumpy - 1/9/06 at 10:35 AM
Was wondering just what it is that determines the required length of front wishbones? Chassis, steering rack? I'm going for the standard chassis front from the McSorley plans so I gather my wishbones will just be as is in the 'book', but just got me wondering as I feel I'm overlooking summat.
phelpsa - 1/9/06 at 10:41 AM
The steering rack, but you can make extensions
StevieB - 1/9/06 at 10:45 AM
As far as I can gather, the wider the better (working on motorcycle principles, the longer the swing arm, the better the handling/smoother ride). And obviously a wide car handles better through the corners.
Other than that though, I can only assume the steering rack is a general basis for the from track.
MK shorten the sierra rack and use extentions to the track rods, so I guess you can have whatever dimensions you want at the end of the day.
mistergrumpy - 1/9/06 at 10:48 AM
Hmm, so if I used book bones on a book chassis with a Sierra rack, would the rack have to be cut? Wonder if I can get around rack mods. Don't mind the extensions to the track rod ends but rack mods seem a bit too much.
StevieB - 1/9/06 at 10:59 AM
The actual rack stays the same, it's just the casing that gets cut down and welded in the middle.
Having said that, I'd avoid using a sierra rack and go for the escort version, as the sierra item is a hideous and heavy unit.
ecosse - 1/9/06 at 11:03 AM
The width of the front bones will likely depend on the back axle width i.e. if using sierra/capri/cortina axles on a book chassis the front bones would be best to be wider than book or it may look odd (not sure what it would do to the handling)
The consensus seems to be that all racks will be best shortened on a standard width chassis (to avoid bump steer), although the escort rack should be a straight fit on a +4 chassis
Alex
nick205 - 1/9/06 at 11:09 AM
MK narrow the whole steering rack (casing and actual rack). the reason being to bring the inner pivot points of the track rods vertically in-line with the inner pivot points of the lower wishbones. This is done to minimise the effects of bump-steer (where suspension movement induces unwanted sterring effect). Extensions are then fitted to the outer ends of the track rods to restore the overall track width of the modified rack back to original Sierra dimensions.
James - 1/9/06 at 11:22 AM
And also, it should be added, to get the rack mounts *inside* the car! As they're too wide for the car as it is.
James
mistergrumpy - 1/9/06 at 11:24 AM
Hmm, Escort rack then, thanks for the tip. Does anyone have any dimensions for the front bones then for the standard chassis with a Sierra De Dion rear axle. I only ask because I can't get my RHS today because of half day finishing and I seem to have found some tubing in the garage so was going to have a bash at knocking some up over the weekend. Got an itchy trigger finger
nick205 - 1/9/06 at 11:31 AM
good point james
StevieB - 1/9/06 at 11:41 AM
I though the sierra rack casing only was shortened to fit inside the body to make a neat job - oops!
What would be really good would be to find a rack of the right dimensions that has a nice alloy casing, rather than the heavy, rusty beast that the sierra unit is!
MikeRJ - 1/9/06 at 12:46 PM
I have an alloy Sierra rack, I didn't realise they were ever made in iron.
ecosse - 1/9/06 at 12:48 PM
+4 inches (total width) or 2 inches each side on the book dimensions is how I did mine.
Alex
procomp - 1/9/06 at 12:55 PM
Hi for the standard book front just use a std escort rack with or whithout extensions to suit the whishbones your going to use. Positioning the rack to suit after will take care of the bumpsteer.
cheers matt
StevieB - 1/9/06 at 01:42 PM
My sierra rack is a bit funny - half seems to be allow, but the other half is caked in rust, so obviously ferous. In my opinion, the whole things is far too heavy for the locost application, it'd be nice to find a lightened casing to use that is the right size for locosts - anyone own a machine shop that could turn these out?
nick205 - 1/9/06 at 01:57 PM
All the Sierra steering racks I've seen (PAS and non PAS) have been alloy cased. Are you sure it's off a Sierra?
A good clean with gunk and a stiff brush should bring it up almost like new.
StevieB - 1/9/06 at 02:40 PM
My steering rack (and all donor parts) came from MK - the rack was already modified. I'll degrease it and give a good scotchbriting (the best rust remover and aluminnium cleaner ever invented!) and see how it comes out. Would still be nice to have a lighter unit (does anyone know if the escort units can be fitted to the MK easily?)
PS - Apologies if I've hijacked the thread, sorry! Rescued attachment Steering Rack and Track Rod Ends.jpg
mistergrumpy - 1/9/06 at 03:21 PM
No worries over hi jacking Stevie, I'm soaking all the info up myself.
Ah but is yours a book chassis, says 442 on your avatar don't it. What concerns me is the length though.
StevieB - 1/9/06 at 03:24 PM
This is first time I've really looked at my steering rack - I'm fairly sure the two halfs aren't from the same car!
mistergrumpy - 1/9/06 at 03:29 PM
Hmm, one of the ball joints looks different to the other don't it. Ones round and ones flared?
StevieB - 1/9/06 at 03:34 PM
They're both flared, but on the same side, so obviously both from the same side of two different cars. That's not a problem, because it'll be new TRE's when I get round to that bit anyway (soon).
What really bothers me is the actual rack casing - I like the principle of less is more, and would really like to get a unit that is smaller and lighter if possible. I have a friend who's got an original Lotus 7 and he was quite taken aback by how ugly and heavy the sierra stuff really is - way off the original concept of being quick because there's no unnecessary weight being carried!
ecosse - 1/9/06 at 04:54 PM
442 chassis (which is the same width as book at front), full width sierra axle and +2" added to each bone to compensate for the wider rear track
Alex
JoelP - 1/9/06 at 05:24 PM
some sierras had steel racks. I own both!
StevieB - 1/9/06 at 06:48 PM
I obviously have half of both!
I was planning on painting it to stop it rusting again - guess I'll have to use a bit of etch primer for the aluminnium part
nick205 - 2/9/06 at 11:39 PM
Joel - I stand corrected on the steel Sierra rack.
StevieB - If it were me I'd go back to MKa nd get them to supply you a modified rack made of ally left and right halves at the very least. I think that's a poor effort on their part
