Hi Gents
Has anyone got any plans for a pedal box, sketches, dimensioned photos, anything!
It’s next on my list of things to do and I quite fancy making my own.
I have tried searching the boards but no joy!
Thought there was a tread for the Dax pedal box a while ago but can’t find it anymore!
Any info would be much appreciated
Thom
rallydesign has a section regarding the ratios to use... pretty useful imo. with that and the measurements from a standard sierra box, u should have
little problems doing a custom pedal box
go to rallydesign.co.uk then online shop and on the right, where it says "tech tips" there's a section called pedal ratios/mechanical
leverage.
Thom,
I designed my own floor mounted pedal box to suit Toyota brake and clutch m/c. I can email you the dwgs if you like.
PM me your email address and I'll send them over.
Tim
Have a look in my archive mate. Theres 3 piccies down the page labelled pedals. They may be of use. I didnt work out any ratios, i just made them
to see what they came out like. They look nice and as luck had it the ratios seem to be perfect. (makes a change i get some luck).
They are all seperate pedals/brackets bolt through the floor with a strengthening plate.
