I have a pair of sierra front uprights to convert to a front hub by cutting the strut down inplace of a cortina unit, with a plate and nut welded to
the top with a ball jointscrewed into it
has anyone else done this,
how much sticking out of the hub carrier did they use,
any photos / drawings would be appreciated....
mk will supply a boss made for the job. Castor camber etc fully adjustable as well
i got two rusty cotina hubs, cut the top taper off, weleded it to a 5mm round plate, then welded that into the top of the strut.
but them im weird.
Knowing now of the adaptors you can buy from peeps like robin hoo /lolocost, id do that
atb
steve
cheers guys, but i'm looking at going by the locost route, and making it myself
the whole point is why pay for somthing i can make for free??? (kinda in keeping with the idea behind ron champions book)
so far at the begining of my build epic i have aquired for a few hours laboring the complete rear, and front suspension setup from a knackered sierra
which i am currently refitting (new seals, bearings, brake components etc).
next will be a J reg sierra i have been offered for the princely sum of 50 quid for the other bits (engine/box & ancils, clocks, wheels, tyres,
loom etc)
this could prove usefull to other builders owing to the number of available cortinas these days.
i went the route of wanting to make all the stuff. before you do that consider.
1. will the item I make be as safe.
2. will I spedn hours of hassle making somethign I could buy for 20 quid, which will be forgotten about as soon as its fitted.
3. You arnt making a diff - you are using one from the car - is an adaptor really breaking any rules.
4. cutting up a strut might be dangerous - are they pressurised with oil or gas?
5. These cars take younks to build, and making up stuff like struts just adds a heck of a lot more yonks.
save 2 - 3 weeks hassle and spend 40 quid on adaptors!
Try to mentally lose the 'ron is a hero' concept. ron wrote a book that inspired, but is full of stupid silly unlikley ways (like free steel
from offcut bins and transit van sides) that dont really work in reality.
atb
steve
[Edited on 18/5/03 by stephen_gusterson]
Hi Steve,
No the struts are not pressurised 'cos I've cut mine down. I've had to go this route 'cos my uprights are 4x4 and the clamp that
takes the upright/adaptor is bigger diameter than a standard Sierra.
See http://mysite.freeserve.com/442/suspension.htm
Hope this helps some,
Martin
<snip>
now you know how pamela anderson feels
Originally posted by stephen_gusterson
.......Try to mentally lose the 'ron is a hero' concept. ron wrote a book that inspired, but is full of stupid silly unlikley ways (like free steel from offcut bins and transit van sides) that dont really work in reality.....
Absolutely well said Steve!
What engineering/manufacturing company scraps useable lengths of square tubing?....Ok, you may get some short offcuts, or handy pieces of 3mm and 16g plate.
Ironically, the steel tubing is one of the cheaper items in the build...
Still, this thread is not about steel tube so I will digress no more, other than to say beware of taking the cost-cutting to extremes that become counter-productive..
.......Thats (fcuk) for alan who may not know UK fashion companies......
thats not a gucchi jumper then?
or a carlos fandango?
Well Ok then except for the Gucci jumper don't get me started....
<snip>
Really? Cos when I cut through the first of a pair of 4x4 rear ones I got showered with something oily and bad tasting!![]()
Be careful!
HTH,
James
I was told I could have some 3/4" ERW for free, but would all be in 25cm lengths! Also, uncle Ron using the "I'm from Oundle
School" line is unlikely to get him anything for free - it's an extremely expensive public school.
Kingr
yes I know - its about 20 mins from where I live.
Leave out the Oundle bit and its not a bad approach.
The ' i will give you a mention in my book' bit might also have been used...
Back to topic !!! :-)
Eddie
"next will be a J reg sierra i have been offered for the princely sum of 50 quid for the other bits (engine/box & ancils, clocks, wheels,
tyres, loom etc)"
You want to knock'em down on that price -something along the lines of I'll remove it for free - unlike the scrappy who'll charge!!
As for upright adaptors - buy them! Simple as that - so you'll go £50 over budget!!
Simon
