Hello all,
Anyone have any information on the degrees of body (chassis) roll per G of any seven type cars?
FWIW I am figuring on 3 degrees or less(hopefully more like 2), but I was curious about others.
Brian
[Edited on 16/9/06 by Tralfaz]
I'm afraid that there will be no two Locosts alike for degrees body roll per G of lateral acceleration...it all depends on the individual setup. Some cars (eg. Lotus and Caterham, as well as a few kit manufacturers) are equipped with anti-sway bars, which will reduce body roll dramatically. I suspect most are not so-equipped, though, as it takes a fair bit of lateral G's to get much roll ouit of a car this light. We're leaving room for anti-sway bars if we need them, but we're going to set up the suspension without first. We can always add 'em in later if we wish...
Agreed.
I was curious if anyone had any data sets of manufactured or perhaps other well developed cars to use as a reference to aid in the development of
mine.
Right now I am working thru Roll Center and Camber change in roll. I have come up with a desirable setup which is good up to about 3 degrees of roll
before losing ideal camber geometry. If I adjust for camber much past this point rollcenter movement suffers notably.
Best Regards,
Brian
I'll answer as I have the info to hand for one I measured:
For a ~ 2000 Caterham Seven Supersport Widetrack the quasi-static total roll per g ( body to ground ) is about 3 degrees, with a linear region up to
about 0.9 g. The measurements showed that the tyres account for about 0.6 degrees per g of the 3 degrees.
I recall a Peugeot 106 GTi I had came out about 2.5 degrees per g total roll. Ferraris and BMWs tend to have 'high' quasi-static total roll
per g, generally in the region of 4 to 6 degrees per g.
In my experience, it is not worth targeting roll per g to any particular figure on Lotus Seven type cars; unless you are racing your car, particularly
on twisty hillclimb or sprint type circuits. The reason is that these cars have very low roll inertias, and thus roll is not often an issue.
Suspension bounce and pitch modes are much more important for road driving in these light cars, particularly here in the UK.
Hope the above helps and that you continue to enjoy setting up the suspension.
Mark
Great Mark,
Thanks so much.
I was trying to ascertain some real world data to help establish some parameters for modelling my Suspension on the computer.
Trying to shrink the number of infinite possibilities
Best Regards,
Brian
For a ~ 2000 Caterham Seven Supersport Widetrack the quasi-static total roll per g ( body to ground ) is about 3 degrees, with a linear region up to about 0.9 g. The measurements showed that the tyres account for about 0.6 degrees per g of the 3 degrees.
I recall a Peugeot 106 GTi I had came out about 2.5 degrees per g total roll. Ferraris and BMWs tend to have 'high' quasi-static total roll per g, generally in the region of 4 to 6 degrees per g.
In my experience, it is not worth targeting roll per g to any particular figure on Lotus Seven type cars; unless you are racing your car, particularly on twisty hillclimb or sprint type circuits. The reason is that these cars have very low roll inertias, and thus roll is not often an issue. Suspension bounce and pitch modes are much more important for road driving in these light cars, particularly here in the UK.
Mark
Originally posted by Tralfaz
I was curious if anyone had any data sets of manufactured or perhaps other well developed cars to use as a reference to aid in the development of mine.
Right now I am working thru Roll Center and Camber change in roll. I have come up with a desirable setup which is good up to about 3 degrees of roll before losing ideal camber geometry. If I adjust for camber much past this point rollcenter movement suffers notably.
Best Regards,
Brian
