Ive just bought a 3.14 diff, Ive seen the picture and it has bolt on shafts, the crown wheel has 3.14 stamped on it, Has it had a lsd conversion or
did they make a 3.14 with bolt on shafts?? It apparently came from a crashed kit car.
Ive been told its deffinatley a 3.14 but not an lsd.
Ive bought it off ebay, there is still a pic on there.
Cheers Andrew.
[Edited on 21/9/06 by dilley]
..."Ive bought it off ebay, there is still a pic on there."
Only if you give us the listing number or link.....
Cant do a link, If you search for 'sierra diff'
you will see it its the only 3.14 listed.
item number 120034096076
you paid £500 for a diff? If it is a 3.14 LSD then it is a 3.14 diff with the internals and bolt on shafts of an LSD. Some would say the ideal combination.
They only made them in open diffs but u can put bolt in shafts from a non-lsd in them
I didnt pay that much
how much did you pay?
i stand to be corrected but if the numbers are stamped into the crown wheel then its probably a new gearset in a 7" lsd diff as all the ford diffs ive had have the numbers painted on them
It's not an LSD.
Liam
