To all those of you fortunate enough to have past the front wish bone part of the build, What did you do with the insides of the bush tubes?...
and the threaded tube for the Top ball joint?
1. Do you paint inside them (I intend to spray the wishbones) or do you leave them?
2. Should I copper grease the threaded tube so it can be adjusted later rather than rust?
What have y'all done?
I dont fancy chroming - it won't fit in with my colour scheme
Many thanks
Danro
Just spray the bones and dont worry about painting the inside of the tubes. Mine only got overspray from the initial spraying. When you push the poly
bushes or normal bushes in it will scrape the paint off anyway.
Cheers David
I was concerned that perhaps the thickness of the paint would cause a prolem getting the bushes in (I have rubber, as I doubt I will be racing).
What have people done about the threaded tube on the top wish bone?
cheers
Danro
try to block the thread up. Ideally screw something in with the right thread, failing that just stuff it up with something.
Thanks JoelP
So when the car is "finished" the thread is still untreated?
That is what I'm trying to get at.
Does it need anything inside, copper grease, grease, WD40 or nothing?
Sorry, I was a little unclear...
Thanks for the help
Danro
Maybe best not to put anything in in case it makes the locknut loose. Id not worry about rust, theres plenty of thickness to work on!
Hmm that brings on the other question..
I HAVE lock nuts and intend to use them, but can't see why I need them.... am I missing something daft?
Should I get my coat and leave?
Am I dangerous?
The way I see it is -
The wishbone can't rotate as it is fixed to the chassis via the 2 bushes and the Track Rod end can't rotate as it is fixed into a mushroom
clamped into the upright.
If any of the components work loose enough to rotate then the locknut will be a little acedmic... but I'm probably missing something basic..
like a brain...
Your views?
Danro
Don't bother with paint. If you are planning to use Metalastic type bushes I would recommend the use of an adjustable reamer to size each tube
to the bush (and to eliminate any distortion caused by the welding).
Am I dangerous?![]()
The wishbone can't rotate as it is fixed to the chassis via the 2 bushes and the Track Rod end can't rotate as it is fixed into a mushroom clamped into the upright.
If any of the components work loose enough to rotate then the locknut will be a little acedmic... but I'm probably missing something basic.. like a brain...![]()
Your views?
plus the housing would be free to rotate even if the 'pin' couldnt. If it fell to one extreme a bump might force it back, which would be extra wear. Probably not much but having no locknut seems very undesirable.
It will fail SVA and MOT without a lock nut as well as being able to turn half a turn either way.
Some excellent points I had been totally unaware of.
Points taken. - Thank you.
Lock nuts will be used, and I now know why!
I'll not be painting inside the tubes and will leave the treaded tube bare.(I will be full of track rod end anyway!)
Hopefully, I have some wheels on in a few weeks... not bad for "huhmmm" years...
Thank you to all who contributed. Much appreciated.
Danro
