Which Uprights?
cm - 28/12/06 at 03:59 PM
Could anyone tell me which uprights I have got? Just bought the car and am not sure. Pic's Below. I need to know as I am ordering some wilwoods for her.
Ian
[Edited on 28/12/06 by cm]
RichieW - 28/12/06 at 04:04 PM
They are Cortina uprights. You have the Cortina M16 Calipers on there at the moment.
ch1ll1 - 28/12/06 at 05:27 PM
yep def cortina !
TimC - 28/12/06 at 05:52 PM
... lose the splash guards!!!
t.j. - 28/12/06 at 06:06 PM
And need some painting to
Humbug - 28/12/06 at 07:14 PM
and scaffolding pole wing stays!
cm - 28/12/06 at 07:21 PM
Ai, don't know why the guards are still on, what do you mean scaffold pole wing stays?
rusty nuts - 28/12/06 at 08:00 PM
At least they shouldn't break like some lightweight items
t.j. - 28/12/06 at 08:16 PM
Too big....
cm - 29/12/06 at 12:16 PM
I will have to sort that out like, I will be stripping the car, re-painting and raplacing some parts, like the wilwoods, perhaps alli hubs etc, i wll be trying to lose as much weight as poss because it currently weigh's 749kg!!!
Any tips of what to lose, the roll bar looks a bit OTT like, seats are comming out to be replaced with GRP, engine will be removed and replaced with a k series, rear spare wheel and mount to be removed, new dash, surround etc. The windscreen looks heavy but also looks good. Front Rad looks fooked, that's my plans so far.
Oh n some new tyres, it's on remoulds!!! Yikes
[Edited on 29/12/06 by cm]
MikeRJ - 29/12/06 at 07:32 PM
Wow, 750kg seems a bit high even with a boat anchor under the bonnet! The floor hasn't been paneled with 1/4" plate has it?
Peteff - 29/12/06 at 11:45 PM
If they are Colway remoulds you should be o.k. as lots of racers use them. Is 749kgs the SVA design weight, it seems a lot for a Locost?
Deckman001 - 30/12/06 at 12:31 AM
Ally Hubs will save you about 2 Kg's, the willwoods will save you more
Jason
RichieW - 30/12/06 at 01:49 AM
I cant believe that comes in at 749 KG!!
The exhaust comes out on the passenger side so I asume it has a crossflow rather than a Pinto. Those wing stays look beefy but even still. 749? Has it been built in 3 mill box section or something?
