when i put the drums onto the hubs, except the studs the surface is completely flat, so i don't have a bit to centralise the wheels.
anybody know why this is or how i could solve this problem?
Is it the hub or the drum that is meant to have the bit on it that centralises the wheel?
Hi Lars, I'm not positive - but i think the centralisation is carried out by the tapers on the wheel nuts. Not sure which wheels you are using, but they should also have a taper for the nut to locate on and centralise the wheel.
Agreed.... the wheel nuts do the centralising.
wicked, i would have probably seen that if my axle came with wheel nuts.
Would it then not also be possible to use the peugeot wheels and centre them using the wheel nuts? cause i remember there being some talk about them
and not being able to centre them properly cause the hole in the centre of the wheel being too big.
Thanks again
