Hi,
Does anyone know of a replacement caliper that will bolt onto a sierra rear hub and fit under a 13" wheel. Handbrake not important....
Cheers, James
I've got sierra rear calipers and handbrake under 13" wheels with no modifications to the caliper.
Originally posted by supercat
Hi,
Cheers, James
Originally posted by the_fbi
Golf ones.
Golf ones.
I thought the Golf ones were the same as the Rally Design Hydra ones and require a minimum 14" wheel?
James
Err, they look more like Sierra ones than Golf ones...
Back again - these are the Golf / Raldes calipers...
They are sierra calipers on the Westy, I have one infront of me now
[Edited on 20/2/07 by Minicooper]
Interesting.... I must admit I've not looked at them since I've seen a pic of the Golf ones, but they were supposed to be Golf ones when I
purchased the car.....
Irrespective of that, Westfield fit the Golf ones and they do fit under 13" rims.
I was hoping not to spend that much money but its looking like my only choice!
Rally Design have said the Golf/Hydra-Mech calipers dont bolt up in place of sierra calipers.... anyone know if thats the case?
James
James
What exactly is it you're trying to achieve?
I've succesfully fitted 13inch alloys over sierra calipers. The westfield solution uses a ford escort front disk at the rear. This has a number
of different dimensions to the sierra disk, from memory moving the caliper towards the diff by 15mm or so, which obviously requires modifications to
the mounting setup.
Chris, is the Hi-Spec offering the one that uses residual brake pressure to operate?
Just trying to sort out which calipers and discs to use on my car. I had previously tried standard sierra calipers with a different 13" wheel and
it didn't fit. I guess I should find some and try with my current wheels.
Cheers, James
Right - I don't yet know if my set-up actually fits but I fugging hope it does... I may get the chance to find out tonight if Lenny's
available and will take a wheel off..
Anyhoo, I have Mark 1 Fiesta front calipers which have lugs that match the Sierra. The offset is different so they need some spacers making up. If
my calculations are right (no guarantee) they'll fit under my 6x13 ET16 Minators.
I'll let you know.
TC
Interesting.... I must admit I've not looked at them since I've seen a pic of the Golf ones, but they were supposed to be Golf ones when I purchased the car.....
Originally posted by TimC
Anyhoo, I have Mark 1 Fiesta front calipers which have lugs that match the Sierra. The offset is different so they need some spacers making up. If my calculations are right (no guarantee) they'll fit under my 6x13 ET16 Minators.
I'll let you know.
TC
A bit of an update...
My wheels foul on the handbrake mechanism on the Sierra caliper (tried one on an Indy last night.) However, I'm confident that they'll go
over the Fiesta calipers.
Will find out on the weekend when I get my bearing carriers back.
TC
