Hi!
I would like to build LHD with CVH.
I am concerned with possible interference of exhaust and steering (both on the same side if I got it correctly)
Anyone done that? Some picture would be appreciated. (Or picture of RHD - pinto combination)
I'd like to see how exhaust pipes were led.
Pinto would be OK I guess for the above problem, Zetec - same problem as CVH.
Also exhaust would be on the same side as driver. What about the noise?
Any other engine suggestion?
if you try searching for related threads it sometimes comes up with some answers...
http://www.locostbuilders.co.uk/viewthread.php?tid=61200
[Edited on 27/2/07 by worX]
Have a lhd. My former seven had a zetec; no problem. I think you can find pics of various westfields with this configuration. Or look at
www.megasportscars.nl
Or do what I did; a 2.0L 20V audi engine; the engine is tall but is tilted to the right. Result; more room for the intake, less lenght of exhaust
headers in the engine bay (and on the right side) and a better weight distribution when you are driving alone...
i would say zeetec no problem.
exhaust is very high, loads of room that side
I would say audi 1.8t
Ford Duratec - exhaust on opposite side from Zetec
