Im looking at getting some DIY brake flexi bits and pieces from raldes...
But..what bore pipe do I need, and which connectors do I need to buy to go on the ends to replicate the origional pipes from the sierra?
Chears.
Dash 3 (-3) hose and metric connectors (M10x1) are what you need.
You can use whatever end you like, I used male bulkhead connectors on the ends of all my hoses.
Make sure that the fittings are of this type with the inner support sleeve, see also SVA manual section 16.4 para 4
[Edited on 18/3/07 by wicket]
