Hi everyone
Just posting some pic's of todays work ,
my Gaz shocks arrived at last , ( NZ customs are not the fastest) Thanks to chris_harris_ for the rear shocks I brought off him "Top man
Chris"
nice - the racks looks like it is sitting too high and too far back - rough rule of t humb isthe track rods should be parallel to ground (yours won't be as there is no weight in the front) plus come out at right angles to the wheels.
i think he means that the track rods, from the steering rack to the wheels should be at 90 degs to the wheels - where as in teh picture it looks like the track rods are not 90degs to the wheel. - almost looks like the steering rack needs to be moved a bit more towards the front of the car.
interesting thing you've done with the rear running gear..... makes me wonder why on earth havent i done that?! is way easier and it justifies
the tradeoff in weight imo... plus you have IRS!
bugger...
Thats right . the steering arms are level with tha arms when at ride height. The front arms are not to book spec's as I brought them off a kit
car company here in NZ so the rack is not in perfect place
The rear end is out of a MX5 and made life alot more simple. it is a bit heavy but as you said its a trade off between weight and simplicity of
build.
Vaughan
