Well after using an engine crane and brute force to turn over my chassis its time to fit the steering column. OK so there is no center bearing and the
nylon bush looks rather ropey.
Anyone know the part nbr or have images of their steering column center mount so I can source the right part?
Will do just now.
Have you got skype and web cam
27030 83pb-30687 comes in three parts outer with a Ali cover and inner with a triangular metal spring clip to hold it
[Edited on 7-5-07 by mangogrooveworkshop]
No sadly not.
I think from the looks of my stering column I'm missing the center bearing so I've ordered one of flea bay. The bush was looking very tired
too.
Ah thanks for the pic. The one I've ordered looks like its all nylon with no metal casing. Shouldn't be a problem though.
[Edited on 7/5/07 by Catpuss]
I take exception to your computer calling me a scumbag.
I think its referrring to your PC, unless you have Windows for Brain Cells installed
This is Macbeast's computer. Who are you calling a scumbag ??
Jezz if you are the computer then the avatar must be a picture of you. In that case I think you are the love child of a PDP 11/75 and babbage's
first offspring
