steering rack knuckle
vorn - 26/6/07 at 09:29 PM
Hi everyone
I found in the search system that a manual sierra down link will fit onto an escort rack. has anyone got a picture of one or a scanned page from a workshop manual so I can confirm with a car wrecker here in NZ that we are talking about the same part.
Vaughan
big_wasa - 26/6/07 at 10:00 PM
Yep The manual rack down link fits
vorn - 26/6/07 at 10:24 PM
Thanks wasa
will thw end "B" fit to the rack ? I need a uj not a flex plate due to the angle.
[Edited on 26/6/07 by vorn] Rescued attachment 300b_1.jpg
robinj66 - 26/6/07 at 10:32 PM
End B fits the triangle shaped upper steering column (the bit that is attached to the steering wheel) so it won't fit the rack without modification
big_wasa - 27/6/07 at 07:53 AM
I am using one of these
You can also buy the UNIVERSAL JOINT
Info on this for you to source near you
UNIVERSAL JOINT
Compact and strong needle roller joint for steering columns.
Accepts 14mm(9/16" ) x 36 spline. Size 80mm x 38mm. 8mm pinch bolts. Forged version only available.
Price £28.00 + P&P
All above taken from THIS PLACE
[Edited on 27/6/07 by big_wasa]
vorn - 27/6/07 at 09:20 AM
Cheers wasa
Thats a handy place. pitty my mother just got back from the UK, would of savde me some freight , I see how I go sorcing bits here , I found a local rally shop with escort uj's for $110 NZD . Its a bit steep .
If anyone has a second universal and is willing to post to NZ I can pay by pay pal .
Vaughan
DarrenW - 27/6/07 at 10:04 AM
For a bit of useless trivia, iirc B squared automotive in Coventry make these for NFauto and some other kit car part suppliers. B2 were set up by ex-NSKSteering systems employees.
im sure some savvy kit car manufacturers could use this bit of useless knowledge if they wanted to buy a batch and make some new I-shafts without having to cutting and shutting Sierra shafts if they wanted to. Knowing that B2 use lots of diffreent yokes and UJ configurations it wouldnt be difficult for them to make a hybrid shaft to suit a particular application. They are set up to do low volume runs.
