I need to extend the wheel studs - does anyone know if they cab be purchased, and from whom? or is it a matter of just getting some machined?
Ford hubs by the way!
believe rallydesign do extended wheelstuds, along with some local motorfactors. also ebay should have some. are you using spacers?
rob
Rally Design supply longer studs.
http://www.rallydesign.co.uk/catalog/index.php?cPath=731_735
i got mine on ebay, worked out at about £1 each with postage.
i know Rally design do stud and spacer sets as well
Theo
Cheers guys...I will be using spacers ont he back but not sure about front yet
Thanks again...
if i were you i would use a good set of hubcentric spacers and not the cast crap you can buy.
hth
rob
