hi all im building a locost book chassis with a mk 2 ford escort axle and standerd book front bones what sort of length front and rear shocks should i be looking for (O and its a crossflow engine if that helps )
do you have the brackets and arms assembled yet? For the back, prop the car up at your desired ride height and measure the gap between the brackets.
This is the length when compressed. Do you know what springs you want on the back? Around 150-200lbs per inch. These would compress roughly 1"
when the car is dropped onto them, so add about 1 inch to get your open length.
It will be around 12" compressed and 13" open.
Front has more potential to vary, and im not very familiar with locost fronts, but a similar approach can be taken. Bear in mind the spring will be at
an angle so will compress a different amount.
Do you know what springs you want on the back? Around 150-200lbs per inch. These would compress roughly 1" when the car is dropped onto them, so add about 1 inch to get your open length.It will be around 12" compressed and 13" open.
ok thanks im going to try to set it all up tomorrow night 1 more question should the trailing arms look level when the ride hight is set right ?
thanks everyone for your help the more info the better.i dont have any susspention brackets welded on yet but the rear axle is on and so are the front
wishbones and uprights
[Edited on 24/7/07 by welshboy]
you want the front lower wishbones level at ride height, and the back about half an inch higher.
Originally posted by Ivan
You need more than 1" travel on the shocks.
The best way to check is to mock up the suspension at your selected ride height and allow at least 2" of bump and 1" of droop from your ride height. - the more you can get away with the better but too much bump will cause bottoming out of your sump or car whichever is the lowest.
At the end of the day it's all governed by your bracket location.
Don't know why the text is italicised![]()
Closed length would be about 9" to give enough travel in both directions.
