Need some inspiration for making a panhard rod bracket for an axle in my rwd 323.
Piccies, drawings, ideas ... anything really. I have an idea in my head of what it needs to look like but I can't quite draw it out !
I seem to remember my old Sylva Striker had a nice neat setup ... anyone got any piccies of one ? all mine don't show the bit I need to see Doh!
Thanks in advance.
[Edited on 25/7/07 by 12a RX-7]
Heres Mine:
is this for the volvo axle ?
Didn't Strikers use a Watts linkage?
minus 500mm Hi the sylva p/rod went from the axle on the drivers side to the bottom of the main chassis tub on passenger side passing underneath the axle and
diff.
The watts type linkage as used in slvas case had a nasty habbit of breaking mounting brackets. And also restricted the axle rotation in the car
badley. Acting as an in built antirollbar meaning it would pick up the inside wheel when cornering and lead to less traction.
Axle travel you should be OK with 1 1/2" droop and 2" bump. Make shure that the axle is allowed to fully droop whithout hitting chassis.
cheers matt
anyone got any Sylva piccies ?
Or is there a sylva forum I can rifle through myself? ( can't think of one)
Cheers ~ Mike
