Hi Guys
Need help identifying the gearboxes I have been given with my part built Locost.
Engine 1.6 Pinto and Axle is Sailbury type A
So I think the drive train may be EX Capri
Gearbox 1
NB 79
624 525
71W6 7006 KA ( not sure about first No 6 )
Gearbox 2
IF 14
833T 7006 AA
71B8 7006 JD ( the B may be an 8 )
Any help on this would be great.
RD
any pics ??
have you looked here ?
https://www.burtonpower.com/default.aspx?/tech_support.aspx
Photos of the gearboxes would be easier to identify, if you have access to a camera?
4 speed or 5 speed?
Tom
Thanks Mcerd1
Will post some pic's Burtons link looks good I will ponder over it tonight
RD
these any help.
http://www.zetecinside.com/xr2/gearbox.htm
http://www.domsat.co.uk/pages/gearboxes.htm
Thanks Guys
The Burton site was useful
I think I have 1 type 3
and 1 type E (rocket)
What do you think ?
RD
Rocket isn't a gearbox type it is a set of close ratios that are fitted in the Type E gearbox as fitted to the original RS2000.
Likewise the 2000e and Bullet were semi-close and close ratio gear sets that were optionally fitted to the Mk1/2 Cortina or type 3 gearbox casings.
A close ratio or semi-close ratio gear set such as the Rocket, Bullet or 2000e is worth having. in a light sports car.
Only way to tell if you have a rocket gearbox is to check the 1st and 2nd gear ratios by counting input and output shaft turns.
