hi there i am building a nissan powerd locost and i have come to make the diff area and one of the drive shafts are shorter then the other and if i get the drive shafts equal on both sides the diff anit in then middle then has any one used an s14 diff and what have they done about th e problem i throught about making a spacer where thr drive shaft bolts to the diff would this work
Dont know about the nissan diff and drive shafts BUT the sierra diff has one driveshaft shorter than the other.
Paul
this is how it works with the sierra diff
Jasper's got a Nissan engine... not sure what diff, though.
i'm using a nissan engine and box but using ford diff
how can i get round the problem then as the pic of the sieera diff is the same as mine
What problem?
The shafts are different lengths so that the diff is in the middle.
Or are you saying your diff is like the sierra's but your shafts are equal length?
Liam
na my drive shafts are different lengths but when i get the diff in the middle the prop dont go don the middle
I would look at the nissan where the diff came from and then set it up that way. i.e. - does the Nissan have the prop flange in the centre of the car
or off to one side.
It's fairly normal to have your prop flange an inch or two to one side as universal joints work best if not in a straight line - nearly all solid
axles are that way.
i solved the problem now it does fit it fitted from the begining the problem was that i took the drive shafts off and then but them on the wrong side so it would nether of lined up so thanks for all your help from the begin it was me being stupied
