Please help
P4 - 4/10/03 at 05:05 PM
Rear drums
Hi,
I have posted this before but received no replies. Come on someone must know the answer.
I have a complete set of rear drums brakes from a Capri. Does any one know if these can be fitted to the Escort axle. Everthing seems to line up and they have a deeper recess on the back plate so the track should be the same. Are there any other problems to consider.
flyingkiwi - 4/10/03 at 05:15 PM
my opinion is to try it and see, if it lines up ok try rebuilding the axle and give the wheels a spin, if there's no graunching noise from deep within whack on the handbrake and see if it stops. The only problem could be plumbing in the brakes, but a bias pedal should sort that out, if its a problem.
Sorry I can't be of any more help, but one thing I have discovered about building this car is that you learn to adapt and overcome things like this. Where there is a will there is a way....
Chris
Just had to add this
Wohoooo! 100 posts!
JoelP - 4/10/03 at 05:37 PM
You've been here all year! obviously too much time building and not enough chatting!!!
yesterday i spent 9 hours on the car and a couple of hours floating between ebay, here and age of empires!
the joys of 'self-employment'!!!
