Anybody used one in an IRS or De Dion setup? I've heard they are a lot lighter than the traditional Sierra unit (that could be wrong!). They
should be tough enough!
The rear mounting points don't look so good though for De Dion
Regards
Wyn
trust me..it is a long mofo.
strong but probably heavy, if not separated mine yet
impreza my96WRX rear running gear
[Edited on 11/1/08 by meany]
i believe that some strikers are running a 4.4 scooby diff...but from what i remember it was shorter than that one...
may have been a justy diff, no idea what they look like
Thanks Guys
meany - are you using the one in the picture in your McSorley build?
I'd be interested to know what weight it is. There are loads of them out there and quite cheap as well. Are they all LSD's?
Wyn
i was gonna use it all to start with, but then changed my mind and went sierra.
the engine width was the deciding factor.too wide for a 7 type
impreza turbo/wrx sti are all rear LSD as far as i am aware, not sure about other models.
