found these on the rallydesign site, look a nice bit of kit, bit expensive but good on a new kit
LINKY
also these are abit cheaper.
have got the raceleda syle ones from rallydesign, and they weigh bugger all compared to the cast/forged steel item from ford.
Yes I've used them on my MiniMojo build
I take it that your mojo suspension isn't finished? ie threads through the nylox
Does anyne know what weight these ones are, also what weight is a standard cortina upright???
[Edited on 14/1/08 by madrallysport]
Nah!
Nothing is bolted together properly!
I'm trying to get everything put together before i strip it, powder-coat the chassis and build for real. You may also notice that the bottom arm
is a little short. Had some new ones made By Jeremy Phillips at no extra cost 25mm longer.
I'll not be torquing anything up till I'm 100% happy!
